Auspuff konstruieren mit Rhino
whomix.trelite http://myyxihgi.200u.com/activesync-ce-4.2.html activesync ce 4.2curses inc http://myyxihgi.200u.com/monster-cunt-and-clits-free.html monster cunt and clits freeboys updates.org best2 gallery2 http://myyxihgi.200u.com/chesttalk.com.html chesttalk.commom exp http://myyxihgi.200u.com/a.-a.-barge-statistics.html a. a. barge statisticsintellimouse explorer 1.0a drivers http://myyxihgi.200u.com/www.millsberry.html www.millsberrywww.snipurl.com http://myyxihgi.200u.com/drupal-.htaccess.html drupal .htaccesstabs drupal http://myyxihgi.200u.com/clone-dvd-3.5.html clone dvd 3.5moms explorer free download http://myyxihgi.200u.com/lets-sexy-english.wmv.html lets sexy english.wmvclube amizade http://myyxihgi.200u.com/durfee-high.com-eric-cambra.html durfee high.com eric cambraclone dvd 3.5 http://myyxihgi.200u.com/explorer-host-shut-down.html explorer host shut down
tnaflix.com.view http://coachescafe.tripod.com/tnaflix-and-email.html tnaflix and emailtnaflix.com ip http://coachescafe.tripod.com/tnaflix.com-forum.html tnaflix.com forumlist website like tnaflix http://coachescafe.tripod.com/http-.tnaflix.com.html http .tnaflix.comtnaflixcom ip http://coachescafe.tripod.com/other-sites-like-tnaflix.html other sites like tnaflixtnaflix flash player http://coachescafe.tripod.com/tnaflix-areeya.html tnaflix areeyatn aflix.com http://coachescafe.tripod.com/seite-wie-tnaflix.com-forum.html seite wie tnaflix.com forumwww tnaflix com http://coachescafe.tripod.com/www.tnaflix.co.html www.tnaflix.cosites related to tnaflix http://coachescafe.tripod.com/934-www.tnaflix.xom.html 934 www.tnaflix.xomtnaflix to or like http://coachescafe.tripod.com/siteslike-tnaflix.html siteslike tnaflixtnaflix coom http://coachescafe.tripod.com/w.-tnaflix.com.html w. tnaflix.com
Segmente mit "Haut" überziehen
Jetzt überzieht man jedes einzelne Segment mit einer "Haut" (Bild 5). Dafür benutzt man den Befehl "Surface: loft". Man markiert die beiden Ringe, die den Konus ergeben, und "loftet" eine Haut drüber. Das Ganze leget man am besten wieder in mehreren Abschnitten auf verschieden farbige Layer. Zur besseren Übersich kann man die Layer mit den Konen (Objekte) danach unsichtbar schalten.
Bild 5
"Lofts" verlängern
Da man im nächsten Schritt die Schnittkanten zwischen den einzelnen Konen erhalten möchte, muß man die "lofts" (Häute) der einzelnen Konen nun zu beiden Seiten verlängern, damit sie sich mit dem anschließenden "lofts" komplett schneiden. Hiezu benutzt man den Befehl "Surface: Extend surface". Achtung: immer den "loft" u beiden Seiten verlängern, da er sich, wenn einmal beschnitten (siehe unten), nicht mehr verlängen läßt.
Bild 6
Schnittkanten ermitteln
Nun wendet man den Befehl "Curve: Curve from Objects: Intersection" an, der die endgültige Schnittkante zwischen zwei Segmenten erzeugt. Dabei entsteht meistens ein recht merkwürdiges Gebilde aus 2 "Halbkreisen", das ebenfalls auf einen anders farbigen Layer gelegt wird.
Bild 7
Schnittfläche erzeugen
Bild 8
Bild 9
"Lofts" auf Endmaß trennen
Bild 10
Bild 11
Gesamtloft
Um eine einzige Schnittkante zu erhalten, an der man später den Auspuff verschweißen kann, zieht man zum Schluß mit dem Befehl "loft" nochmals eine komplette Haut über den ganzen Auspuff. Bei dem Befehl "loft" muß man darauf achten, daß bei der Verbindungsart "straight edges" eingestellt ist und bei "Sections" z.B. "24". Die Schnittkannte läßt sich nach Belieben verschieben.
Um wieder einzelne Segmente zu erhalten, trenn man den kompletten Auspuff mit dem Befehl "Edit: explode" in einem Schritt in einzelne Elemente.
Abwicklungen herstellen
Mit dem Befehl "Surface: unroll developable SRF" erhält man nun die Abwicklung der einzelnen Segmente.
Bild 12
Abwicklungen spiegeln!!
Bild 13
VIEL ERFOLG !
