Auspuff konstruieren mit Rhino
www.blog.fupps.com http://juleseus.host-ed.net/eternitycaptured.com-blog.html eternitycaptured.com blogmaine tax credits http://juleseus.host-ed.net/r.-kelly-fiesta-credits.html r. kelly fiesta creditswww.waybig.com http://juleseus.host-ed.net/blog.l.html blog.lzing.waybig http://juleseus.host-ed.net/earn-p.a.c.e-credits.html earn p.a.c.e creditsdr. ellis tax credits http://juleseus.host-ed.net/waybig-.com.html waybig .comwww.amateur blog http://juleseus.host-ed.net/waybig.com-october.html waybig.com octobergenkiworld.blog spot.cvom http://juleseus.host-ed.net/ivy-blog-dr.-block.html ivy blog dr. blocktransferring college credits .edu http://juleseus.host-ed.net/free-sex-videos-blog.na.html free sex videos blog.nad pitty blog.com http://juleseus.host-ed.net/www.boogie-blog.com.html www.boogie blog.comgenkiworld.blog spot.com http://juleseus.host-ed.net/john-williams-e.t.-credits.html john williams e.t. credits
falcon 4.0 pdf manual http://mpseygasqua.agilityhoster.com/info-independent-theatre-workshop.com.html info independent theatre workshop.comcraft workshop.com.au http://mpseygasqua.agilityhoster.com/accueil-flers.citroen.fr.html accueil flers.citroen.frcitroen.rf http://mpseygasqua.agilityhoster.com/www-citroen.fr.html www citroen.frbild a bear workshop.com http://mpseygasqua.agilityhoster.com/no.-8-workshop-takakpuna.html no. 8 workshop takakpunafredsresin workshop.com http://mpseygasqua.agilityhoster.com/psp-2.71-manual.html psp 2.71 manualunsecure v 1.2 manual http://mpseygasqua.agilityhoster.com/sad-citroen-chambery-wanadoo.fr-h.html sad citroen chambery wanadoo.fr hsoca.soca citroen wanadoo.fr http://mpseygasqua.agilityhoster.com/lotus-approach-9.5-manual.html lotus approach 9.5 manualhero workshop .torrent http://mpseygasqua.agilityhoster.com/am75-rev.d-manual.html am75 rev.d manualdenon 7.1 owner s manual http://mpseygasqua.agilityhoster.com/workshop.com.html workshop.comsartan s leather workshop http://mpseygasqua.agilityhoster.com/download-hero-workshop.torrent.html download hero workshop.torrent
Segmente mit "Haut" überziehen
Jetzt überzieht man jedes einzelne Segment mit einer "Haut" (Bild 5). Dafür benutzt man den Befehl "Surface: loft". Man markiert die beiden Ringe, die den Konus ergeben, und "loftet" eine Haut drüber. Das Ganze leget man am besten wieder in mehreren Abschnitten auf verschieden farbige Layer. Zur besseren Übersich kann man die Layer mit den Konen (Objekte) danach unsichtbar schalten.
Bild 5
"Lofts" verlängern
Da man im nächsten Schritt die Schnittkanten zwischen den einzelnen Konen erhalten möchte, muß man die "lofts" (Häute) der einzelnen Konen nun zu beiden Seiten verlängern, damit sie sich mit dem anschließenden "lofts" komplett schneiden. Hiezu benutzt man den Befehl "Surface: Extend surface". Achtung: immer den "loft" u beiden Seiten verlängern, da er sich, wenn einmal beschnitten (siehe unten), nicht mehr verlängen läßt.
Bild 6
Schnittkanten ermitteln
Nun wendet man den Befehl "Curve: Curve from Objects: Intersection" an, der die endgültige Schnittkante zwischen zwei Segmenten erzeugt. Dabei entsteht meistens ein recht merkwürdiges Gebilde aus 2 "Halbkreisen", das ebenfalls auf einen anders farbigen Layer gelegt wird.
Bild 7
Schnittfläche erzeugen
Bild 8
Bild 9
"Lofts" auf Endmaß trennen
Bild 10
Bild 11
Gesamtloft
Um eine einzige Schnittkante zu erhalten, an der man später den Auspuff verschweißen kann, zieht man zum Schluß mit dem Befehl "loft" nochmals eine komplette Haut über den ganzen Auspuff. Bei dem Befehl "loft" muß man darauf achten, daß bei der Verbindungsart "straight edges" eingestellt ist und bei "Sections" z.B. "24". Die Schnittkannte läßt sich nach Belieben verschieben.
Um wieder einzelne Segmente zu erhalten, trenn man den kompletten Auspuff mit dem Befehl "Edit: explode" in einem Schritt in einzelne Elemente.
Abwicklungen herstellen
Mit dem Befehl "Surface: unroll developable SRF" erhält man nun die Abwicklung der einzelnen Segmente.
Bild 12
Abwicklungen spiegeln!!
Bild 13
VIEL ERFOLG !
