Technisches Wörterbuch
| Deutsch | Italienisch | Französisch | Spanisch | Englisch |
| Achse | asse | ### | ### | axle |
| Ansaugstutzen | ### | pipe d'admission | ### | ### |
| Aufkleber | adesivi m | ### | ### | sticker |
| Auspuff | marmitta f | pot d’échappement | ### | exhaust |
| Backe | cofano m | aile | cubre | cowl |
| Beilagsscheibe | rondella f | rondelle | arandela | washer |
| Benzinhahn | rubinetto m | robinet d'essence | grifo mezcla | fuel cock |
| Benzinhahnschlüssel | chiave rubinetto | clef demonte robinet | ### | tap fixing key |
| Blinker | lampeggiatori m | clignotant m | ### | indicators |
| Bolzen | perno | boulon | ### | pivot |
| Bremsbacken | ganascia freno | mâchoire de frein | zapata freno | brake pads |
| Bremshebel | leva freno | levier de frein m | ### | brake lever |
| Bremspedal | pedale freno m | ### | pedal freno | brake pedal |
| Bremstrommel (_ vorne/_ hinten) | tamburo m (_ anteriore/_ posteriore) | tambour de frein | tambor freno (_ delantero/_ trasero) | brake drum (front _/rear _) |
| Chokehebel | ### | tirette de starter | ### | ### |
| Dichtung | guarnizione | joint m oder garniture | ### | gasket |
| Ersatzradhalter | porteruota di scorta | porte roue de secours | soporto rueda de recambio | spare wheel bracket |
| Fächerscheibe | rondella dentellata f | ### | arandela dentada | star washer |
| Feder | molle m | ressort f | muelle | spring |
| Federklammer | anello elastico | ### | ### | circlip |
| Federscheibe | rondella elastica f | ### | arandela grower | spring washer |
| Felge | cherchione m (Mz. -i) | jante | llanta | wheel nave |
| Felgenmutter | dado cerchione m | ### | ### | wheel rim nut |
| Gaszug | gavetto gas m | ### | ### | throttle cable |
| Gepäckbrücke | portasella f | ### | ### | plate carrier |
| Gepäckträger | portapacchi m | porte bagage | porta equipajes | carrier |
| Halteblech | piastrina fissagio | ### | ### | fixing plate |
| Hauptdüse | getto maximo m | ### | gicleur del maximo | main jet |
| Hauptständer | cavalletto centrale m | béquille | pata caballete | central stand |
| Hauptwelle | ### | arbre de boite de vitesses | ### | ### |
| Hupe | clacson m | avertisseur | claxon | horn |
| Kabelbaum | gruppo cavetti m oder impianto elettrico m | faisceau | grupo cables | cable harness |
| Kaskade | copristerzo m | calandre | ### | front mask |
| Kickstarter | leva avviamento | kickstarter | pedal puesta en marcha | kickstarter |
| Klemmspiegel | specchietto a molletta m | ### | ### | legshield mirror |
| Kolben | pistone m | piston m | pistón | piston |
| Kolbenbolzen | spinotto m | axe du piston | ### | wrist pin |
| Kolbenbolzenclip | anello elastico per spinotto m | circlip d'axe de piston | anillo elástico eje de pistón | circlips for wrist pin |
| Kolbenring | anello per pistone m | bague | segmento por pistón | piston ring |
| Kolbenstopper | blocca pistone | ### | ### | piston stopper |
| Kondensator | condensatore f | condensateur | condensador | condenser |
| Kotflügel | parafango m | garde-boue | guardabarros | mudgard |
| Kotflügelnase | cresta parafango f | crête de garde-boue | ### | mudgard crest |
| Kronenmutter | dado corona | ### | ### | collar nut |
| Krümmer | tubo scarico m | ### | ### | outlet pipe |
| Kupplung | frizione | embrayage | embrague | clutch |
| Kupplungsabzieher | togliafrizzione | extracteur d'embrayage | ### | clutch dismounting tool |
| Kupplungstrennpilz | rallino frizione m | ### | bulón empuje embrague | activating plate |
| Kurbelwelle | albero motore m | arbre moteur oder embiellage | gigüeñal | crankshaft |
| Lager | cuscinetto m | roulement | ### | bearing |
| Lampensockel | porta lampada f | ### | portalámparas | bulb socket |
| Lenker | manubrio m | guidon | manillar | handlebar |
| Lenkergriff | manopola f | ### | ### | handlebar grip |
| Lenkerschloß | bloccasterzo m | neiman | ### | steering lock |
| Lichtschalter | commutatore luci m | commutateur | conmutador luz | light switch |
| Lichtspule | bobina luci f | bobine d'alimentation | ### | light coil |
| Lüfterradabdeckung | copriventola | cache turbine | tapa volante magnético | flywheel cover |
| Luftfilter | filtro dell'aria m | filtre à air | filtro de aire | airfilter |
| Motor | motore m | moteur | motor | engine |
| Motordeckel | sportello motore m | portiere moteur | portezuela del cubre-motor | engine cowl flap |
| Mutter | dado m (Mz. -i) | écrou m | tuerca | nut |
| Nabendeckel | tappo del tamburo m | ### | ### | brake drum plug |
| Nadel (Lager) | rullino m | (roulement à) aiguilles | ### | needle |
| Nebendüse | getto minimo m | ### | gicleur del minimo | idling jet |
| Niete | perno m | rivet f | ### | pin |
| Ölablassschraube | tappo olio m | écrou de vidange | tapón aceite | oil plug |
| Polrad | volano m | volant | rotor volante | flywheel |
| Polradabzieher | togliaventola | extracteur de volant | ### | fan dismounting tool |
| Rad | ruota f (Mz. -e) | roue | rueda | wheel |
| Radachse | asse ruota | ### | ### | wheel axle |
| Rahmen | telaio m | châssis oder coque | bastidor | chassis oder frame |
| Rücklicht | fanalino posteriore m | feu arrière | piloto | rear lamp |
| Rückspiegel | specchio m | rétroviseur | ### | mirror |
| Rückspiegelhalter | staffa per supporto specchio | ### | ### | mirror bracket |
| Schaltgabel | innesto per cambio m | ### | ### | ### |
| Schalthebel | leva frizione | ### | ### | lever for clutch |
| Schaltkreuz | crocera | croisillon de changement de vitesses | ### | cruciform |
| Scheinwerfer | fanale anteriore m oder faro | phare avant | faro delantero | head lamp |
| Scheinwerferblende | visiera per faro anteriore | visière de phare | ### | ### |
| Scheinwerferchromring | cornice cromato per faro | cerclage de phare chromé | bisel | chromed headlamp rim |
| Schmiernippel | ingrassatore m | ### | ### | grease nipple |
| Schnarre | raganella f | ### | ### | rattle |
| Schraube | vite f | vis f | tornillo | screw |
| Schraube | bullone m | boulon | ### | bolt |
| Schwimmer | galleggiante m | flotteur m | ### | floater |
| Schwimmernadel | spillo conico m | pointeau | ### | floats needle |
| Schwingenabdeckung | coperchio mozzo m | ### | tapa buje | wheel hub cover |
| Schwingenbolzen | perno ruota | ### | ### | front wheel pivot assy |
| Schwingsattel hinten | sella posteriore f | selle arrière | sillín | rear saddle |
| Schwingsattel vorne | sella anteriore f | selle avant | sillín | front saddle |
| Seilzug (komplett) | transmissone m | transmission | ### | transmission |
| Sicherungskeil (Halbmondkeil) | chiavetta f | clavette | chaveta | key |
| Simmerring | paraolio | ### | ### | oil seal |
| Sitzbank | sella biposto f | ### | sillín largo | dual seat/saddle |
| Sitzbankzapfen | perno aggancio sella biposto | ### | perno del sillín | saddle lock pin |
| Soffite | lampadina siluro | ### | ### | fuse type bulb |
| Splint | coppiglia | goupille | ### | split pin |
| Ständerfüße | scarpette in gomma | sabot | zapatos | stand pad |
| Stoßdämpfer | ammortizzatore m | amortisseur | amortiguador | damper |
| Stoßdämpferfeder | molle sospensione m | ### | muelle suspensión | suspension spring |
| Tacho | contachilometri m | compteur-kilométrique | cuentakilometros | speedometer |
| Tachoritzel | rocchetto m | ### | ### | speedometter drive pinion |
| Tachoschnecke | ### | engrenage de transmission de compteur | ### | ### |
| Tachowelle | pignone contakilometri | transmission de compteur | ### | speedo cable |
| Tank | serbatoio | réservoir | déposito | fuel tank |
| Trittleisten | listelli pedana m | baguettes de sol | tira reposapiés | floor rails |
| Unterbrecherkontakte | ruttore m | rupteur | ruptor | contact breaker |
| Vergaser | carburatore m | carburateur | carburador | carburettor |
| Vergaserdeckel | sportello carburatore m | trappe carburateur | ### | ### |
| Werkzeugfach | sacca per attrezzi | coffre à outils | caja porta de herramientas | tool box |
| Zierfelge | borchia per ruota f | ### | ### | wheel boss |
| Zoll (Maßeinheit) | pollici | pouce m | ### | inch |
| Zündgrundplatte | supporto bobine | plateau d'allumage | ### | back plate assies |
| Zündkerze | candela | bougie | ### | spark plug |
| Zündspule | bobina di alimentazione f | bobine de haute tension | ### | high tension coil |
| Zug (Kabel) | cavetto m | câble | ### | cable |
| Zughülle | guaina | gaine | ### | sheat |
| Zylinder | cilindro m | cylindre | cilindro | cylinder |
| Zylinderkopf | testa-cilindro | culasse | culata | cylinder head |
| Zylinderhutze | calottina cilindro f od. cuffie per cilindro | cache cylindre | ### | engine cowl |
to be continued...
