Technisches Wörterbuch
| Deutsch | Italienisch | Französisch | Spanisch | Englisch |
| Aufkleber | adesivi m | ### | ### | sticker |
| Auspuff | marmitta f | pot d’échappement | ### | exhaust |
| Backe | cofano m | ### | cubre | cowl |
| Beilagsscheibe | rondella f | rondelle | arandela | washer |
| Benzinhahn | rubinetto m | ### | grifo mezcla | fuel cock |
| Bremsbacken | ganascia freno | ### | zapata freno | brake pads |
| Bremspedal | pedale freno m | ### | pedal freno | brake pedal |
| Bremstrommel (_ vorne/_ hinten) | tamburo m (_ anteriore/_ posteriore) | ### | tambor freno (_ delantero/_ trasero) | brake drum (front _/rear _) |
| Ersatzradhalter | porteruota di scorta | ### | soporto rueda de recambio | spare wheel bracket |
| Fächerscheibe | rondella dentellata f | ### | arandela dentada | star washer |
| Feder | molle m | ### | muelle | spring |
| Federscheibe | rondella elastica f | ### | arandela grower | spring washer |
| Felge | cherchione m (Mz. -i) | jante | llanta | wheel nave |
| Felgenmutter | dado cerchione m | ### | ### | wheel rim nut |
| Gepäckträger | portapacchi m | ### | porta equipajes | carrier |
| Hauptdüse | getto maximo m | ### | gicleur del maximo | main jet |
| Hauptständer | cavalletto centrale m | ### | pata caballete | central stand |
| Hupe | clacson m | avertisseur | claxon | horn |
| Kabelbaum | gruppo cavetti m oder impianto elettrico m | connexions électriques | grupo cables | cable harness |
| Kaskade | copristerzo m | ### | ### | front mask |
| Kickstarter | leva avviamento | kickstarter | pedal puesta en marcha | kickstarter |
| Klemmspiegel | specchietto a molletta m | ### | ### | legshield mirror |
| Kolben | pistone m | piston m | pistón | piston |
| Kolbenbolzen | spinotto m | axe du piston | ### | wrist pin |
| Kolbenbolzenclip | anello elastico per spinotto m | ### | anillo elástico eje de pistón | circlips for wrist pin |
| Kolbenring | anello per pistone m | bague | segmento por pistón | piston ring |
| Kondensator | condensatore f | ### | condensador | condenser |
| Kotflügel | parafango m | garde-boue | guardabarros | mudgard |
| Kupplung | frizione | embrayage | embrague | clutch |
| Kupplungstrennpilz | rallino frizione m | ### | bulón empuje embrague | activating plate |
| Kurbelwelle | albero motore m | arbre moteur | gigüeñal | crankshaft |
| Lampensockel | porta lampada f | ### | portalámparas | bulb socket |
| Lenker | manubrio m | guidon | manillar | handlebar |
| Lenkerschloß | bloccasterzo m | ### | ### | steering lock |
| Lichtschalter | commutatore luci m | commutateur | conmutador luz | light switch |
| Lichtspule | bobina luci f | ### | ### | light coil |
| Lüfterradabdeckung | copriventola | ### | tapa volante magnético | flywheel cover |
| Luftfilter | filtro dell'aria m | filtre à air | filtro de aire | airfilter |
| Motor | motore m | ### | motor | engine |
| Motordeckel | sportello motore m | ### | portezuela del cubre-motor | engine cowl flap |
| Mutter | dado m (Mz. -i) | ### | tuerca | nut |
| Nebendüse | getto minimo m | ### | gicleur del minimo | idling jet |
| Ölablassschraube | tappo olio m | ### | tapón aceite | oil plug |
| Polrad | volano m | volant | rotor volante | flywheel |
| Rad | ruota f (Mz. -e) | roue | rueda | wheel |
| Rahmen | telaio m | châssis | bastidor | chassis oder frame |
| Rücklicht | fanalino posteriore m | feu arrière | piloto | rear lamp |
| Rückspiegel | specchio m | ### | ### | mirror |
| Rückspiegelhalter | staffa per supporto specchio | ### | ### | mirror bracket |
| Scheinwerfer | fanale anteriore m oder faro | phare avant | faro delantero | head lamp |
| Scheinwerferblende | visiera per faro anteriore | ### | ### | ### |
| Scheinwerferchromring | cornice cromato per faro | ### | bisel | chromed headlamp rim |
| Schnarre | raganella f | ### | ### | rattle |
| Schraube | vite f | ### | tornillo | screw |
| Schwingenabdeckung | coperchio mozzo m | ### | tapa buje | wheel hub cover |
| Schwingsattel hinten | sella posteriore f | selle arrière | sillín | rear saddle |
| Schwingsattel vorne | sella anteriore f | selle avant | sillín | front saddle |
| Sicherungskeil (Halbmondkeil) | chiavetta f | ### | chaveta | key |
| Sitzbank | sella biposto f | ### | sillín largo | dual seat/saddle |
| Sitzbankzapfen | perno aggancio sella biposto | ### | perno del sillín | saddle lock pin |
| Ständerfüße | scarpette in gomma | sabot | zapatos | stand pad |
| Stoßdämpfer | ammortizzatore m | amortisseur | amortiguador | damper |
| Stoßdämpferfeder | molle sospensione m | ### | muelle suspensión | suspension spring |
| Tacho | contachilometri m | compteur-kilométrique | cuentakilometros | speedometer |
| Tank | serbatoio | réservoir | déposito | fuel tank |
| Trittleisten | listelli pedana m | ### | tira reposapiés | floor rails |
| Unterbrecherkontakte | ruttore m | ### | ruptor | contact breaker |
| Vergaser | carburatore m | carburateur | carburador | carburettor |
| Vergaserdeckel | sportello carburatore m | ### | ### | ### |
| Werkzeugfach | sacca per attrezzi | coffre à outils | caja porta de herramientas | tool box |
| Zierfelge | borchia per ruota f | ### | ### | wheel boss |
| Zoll (Maßeinheit) | pollici | ### | ### | inch |
| Zündspule | bobina di alimentazione f | bobine de haute tension | ### | high tension coil |
| Zylinder | cilindro m | cylindre | cilindro | cylinder |
| Zylinderkopf | testa-cilindro | ### | culata | cylinder head |
to be continued...
